I’m running a THL Box 1 Pro (S905x , 2Gb) with CoreELEC 19.5 - Matrix_rc2 on an LG UltraWide 38UC99.
The native resolution of the monitor is 3840x1600p @ 60Hz.
I added this resolution to .kodi/userdata/disp_cap and can select it, but the picture is very distorted. I tried 30Hz as well with the same result.
I also enabled the VESA modes in the CoreELEC settings. I tried different HDMI cables as well, but the one I use should work, as it works when I connect a notebook to the monitor.
Am I out of luck or is there a way to get it work?
