Is MVC supposed to work on S905X4-J ? Trying a few BD3D, and with CE-NG 21.2 they all have jumpy behavior, e.g. frame skipping may every few seconds or so, and sounds get out of sync. CE-NE 21.2 is more broken, right eye is greenish, skipping still present. Done-HD Homatics R 4K Pro.
Dune Homatics = S905X4-K. There is no Pro (not yet), and yes, 3D (all formats), should (or could), work just fine with CE but you should take the NG Nightly version maybe?
Sorry. “Dune-HD Homatics R 4k PLUS”, not Pro. Stupid long name.
Any pointer to explanations how to most easily change between a test build and relase build ? Or do i have to go trough new USB Stick installation every time ?
Copy the tar file to the Update folder in the SMB share, and reboot.
I have been trying to play 3D-MVC ISO/MKV as frame-packed 3D on my Dune-HD Homatics R 4K Plus box using Kodi 21.2 latest CE-NG and CE-NE, but playback always “stutters”, aka about every 1 second or so it jumps a bit. Played from NAS via Gbps, played from USB3 /storage directory, no difference. Tried passthrough, tried decode to PCM (jsut in case sync with audio could have made a difference). All the same. Info display does not show any CPU exhaustion, max core utilization below 40%.
How would i have to report this as a bug other then just writing this post here ?
How would i have to report this as a bug other then just writing this post here ? I already posted to the 3D thread, but no reply there.
