i’m using minix U9H with CE 9.2.1 and i noticed my 4k/HDR video are playing as 1080p on my TV.
My setup is Minix -> AVR (Denon X4500H) -> Sony Bravia
To rule out the AVR, i directly connect my Minix U9 to my TV, using premium certified HDMI cable.
Below is the dispinfo result while playing a 4k/HDR content. http://ix.io/28XS
is there a setting I need to enable or disable to play in native 4k / HDR ?
it’s not linked to a particular video file as it happens to all of them.
Also when I set Adjust display refresh rate to on start / on stop, it looks like it works. But after a while, the screen starts to flicker, and becomes black then back to a lower resolution.
I f i set Adjust display refresh rate to off, i’m stuck in 1080p.
