Which 7 port USB 3 hub works on the Odroid N2?
Suggest you look here at all the USB 3 issues with the Odroid N2 that will not be solved with any sort of hub.
That doesn’t answer my question.
There is no reason why any USB hub should not work but this thread may give you an idea of what does work with other boxes.
Just trying to be helpful and informative.
