8.90.3 FFmpeg Invalid return
Is anyone else having issues with FFmpeg after updating to 8.90.3? I keep getting DEBUG: ffmpeg[D9211370]: Invalid return value 0 for stream protocol which prevents it from opening and reading the m3u8 file. Both 8.90.2 and 8.90.3 have FFmpeg v4 so I wasn’t sure if it was Kodi issue or not.
A quick search seems to suggest a FFmpeg issue. I did a test with a clean install with only one addon that uses Fmpeg and got that same results. For now I coded the addon to use inputstream instead.
