I have tried several BD and 4K BD remux. Screen and playing time just stay on the current position.
Fast forward is ok.
Mecool 905X box.
Fast forward is ok.
Mecool 905X box.
Play vídeo and Press OK > key UP (select progress bar) > key Left to
Rewind or Right to Forward
Yes, it will go backward 10 seconds.
I was talking about the rewind key on the remote. When you press once, video normally rewind at 2x, twice 4x, … It doesn’t work in this build.
THX for reporting. The rewind issue will be fixed in next release.
Same here, tested with Ordoid C2.
