I‘m a little bit confused and hope you can help me. At the moment I’m using a RPi 4 with LE with the following ambilight setup:
- WS2801 strips directly connected to the board via SPI
- Hyperion as a grabber
I’d like to use my LePotato though but I couldn’t figure out if it’s possible with my ambilight needs… I don’t want to program an extra Arduino.
So here are my questions:
- Can the SPI Interface be enabled on the LePotato so it can communicate with the WS2801 directly? If yes: how? (Similar to dtparam-spi-enable on RPi)
- Is it then possible to use Hyperion.ng and configure it to use the SPI?
Does anyone have a similar setup or can provide some help?
Thanks a lot for your work!
