Glad to hear that. I think thats wise as I can confirm, that C2 on 3.14 is rock solid with HTPC features working 100%. And backporting SW to older HW could be dodgy sometimes. (not saying I am against one code for all devices, but understand possible pain with that one).
Crossfinger with the new kernel development, it looks very promising even with less effort needed for maintanance, but I now that real life is usual complicated than initial thoughts. Wish the best to the future work guys!
Despite I ordered an âMAGICSEE N5 Max 4K Android9.0 TV Box Amlogic S905X2 Dual WiFi 2+16G BT USB3 HDMIâ I got a magicsee N5MAX S905X3 2+32G device (for the same price :DâŚ). I have chosen this because I want to run coreelec. Sending back and waiting for the right one takes quite a long time - should I wait for X3 support for this or better send it back?
I have an N5 Max and it does work at 1GBit the QC is not brilliant but after I changed the HDMI cable and swapped PSU it worked fine been using for a couple of months and it ok Wifi worked but I use on 1GB ethernet.
I suspect if the SOCs are very similar in price then they will just produce the X3 variant, why produce an X2 and X3 if there is only a $ Difference.
