Hi guys!
I desperately need your support. I am sitting on a MINIX U9-H and I am trying to get my Logitech Harmony Hub working with it. There are a lot of options to get a remote working with Coreelec, but I seem to get stuck somewhere in between. I have read (to many?) threads about this.
I have not tried the “config less” variant, using meson-ir as my box is not supported, just a few, like Tanix Khadas etc.
Question 1. In Harmony SW, can I set up my box like a Tanix instead, and the built in IR protocol in CE will solve the rest?
I managed to find a remote.conf for MINIX U9-H at the MINIX forum, and moved it to storage/configfiles/. but that didn’t di it either. Yes, I rebooted the box also.
Question 2. In some places, I see the config file names as remote.conf, but in other threads I see rc_keymap.conf (or something similiar). Did I do wrong?
I also tried to just remove the conf-file and set up the box as a Microsoft Windows Media Center in Harmony SW. That does not work either.
So, I would just like to add support for basic functionality. Play, OK, Stop and UI navigation (up, down, right, left) and stuff like that. What is my weapon of choice and the best solution for me?
Thanks in advance for reading, and hopefully posting!
