Hi Folks,
is it possible to install the version of aspnetcore that it on Matrix ng builds in to the older non ng builds, and if yes, how would i do it?
i want to install nextpvr direct, without using docker to save the overhead, and put one of my old s912 boxes to good use. i was able to do this without issue on the Matrix CE image, but on the non ng nextpvr fails to start due to missing aspnetcore.
i looked at using armbinan but decided i want to also keep kodi, so i can continue to fill my media folders using artwork beef in an automated way, rebooting nightly by cron, with library set to update on start, so CE potentially would be perfect for this…
