Autoupdate set to auto. My coreelec is ver 8.90.5. Latest version on github is 8.95.4.3
What is the status of auto update?
I think the auto update might have not worked on some of the older releases. If you manually update it should get you to a version where the auto update works again.
Not to highjack your post bukan.ijam, but do you ever shutdown your box?
My main box stays on all the time restarting every two days. It will automatically update but only if I shut it down or reselect “auto” in the CoreELEC settings. At which point the notification pops up and the update is downloaded. I believe this may be a small bug.
