For which version of coreelec is the file intended?
doesn’t matter. it’s the same kernel for both
@Portisch Just tested the latest. Both USB ports are functional, and no more start-up message about Pulse-Eight CEC Adapter error. Enabled Ethernet and tested, working good also.
I am now however receiving every-time I reboot CoreELEC a message.
'… update it to resume normal startup.
… startup in 30s… 29, 28, 27, 26 … ’
Just update tomorrow with the new nightly.
The delay happens as the dtb is not found in default folder. It will be solved by itself when updated.
I don’t use the nightly builds, forced updates and often breaks something I’ve observed. Thanks for the aid with getting USB ports both functional again. Kudos.
Coreelec 9.2.5 - internet ok, when playing online video at regular intervals 3 small consecutive twitches.
I use g12a_s905x2_beelink_gt1_mini_2g.dtb
