A few months ago I did the following to disable IR on my KIII Pro… echo “blacklist meson-ir” >> /storage/.config/modprobe.d/blacklist.conf
I have a few CoreELEC boxes and the KIII Pro is my TV server which kept powering off when I powered off another CoreELEC box so I disabled IR altogether. It has worked fine for ages.
Since the v9.0 upgrade however the IR is working again and I cant disable it. I checked the blacklist.conf file and “blacklist meson-ir” is still in there but seems to be ignored.
