Just found out about CE and want to migrate from LE. Everything works, except Bluetooth 4.0 dongle I used with LE and Logitech Harmony remote.
[USB bluetooth Dongle](https://www.amazon.com/dp/B00OH09OXS/ref=cm_sw_r_tw_dp_U_x_O3FwCb8EFN1EE via @amazon)
Logs here
Firstly thanks for attaching the correct logs.
I can see that the dongle is detected, recognised and loaded by the system.
Have you gone into CE-settings and tried searching for Bluetooth devices?
Thanks. Missed that. Had to piece together how I enabled it on LE, so pasting here for reference:
- Harmony - Add device. Company: Microsoft. Device: Kodi. Harmony & Kodi
- Harmony - create activity, will start Bluetooth pairing
- CoreELEC - Settings - CoreELEC - Bluetooth - pair device. Look for “Harmony Keyboard” in Bluetooth list
