i have k3 pro with new update 9.2.0, my bluetooth is not working. it was working before everytime on rebooted i had to pair it again. I need help?
You can try to download the tar file again and update your box with it.
If the above doesn’t fix it, try the latest nightly build and let us know if it works.
tar update doesn’t work as I expected
sorry, I’m not a fan of nightlies
why should the tar update again help?
have you found the problem?
You don’t have to be a fan of nightlies.
Just try it and tell us if it works.
as I wrote, the 2x update 9.2 doesn’t work
Yes, and if you don’t test the nightly, we won’t know if the problem has been solved or not.
ok, I’ll try later, probably on Sunday
I tried with the latest nightly (CoreELEC-Amlogic-ng.arm-9.2-nightly_20190919-Generic.img.gz), and on my device (Mecool KM9 Pro, S905X2, 16GB/2GB), bluetooth is still not working.
It was working with this : CoreELEC-Amlogic-ng.arm-9.1-devel-1565360317.tar
Found here: https://mega.nz/#!hW5gHYZQ!la2lnraC2mFUCN0kAMHeSkVfxoJPCgN0AYnzAKZItMQ
I’m not sure if the team mirrors nightlies to Mega but I’ve never known it.
Always best to get them from the CE Site as you can never know whether anything from elsewhere has been modified.
I have discovered an issue with the latest NG build with my S905X2 with an external CSR 4.0 dongle, where on boot CE shows bluetooth to be disabled, despite it being turned on, so when I disable and re-enable it tells me that no bluetooth adapter can be found.
lsusb confirms that it cannot be seen and every reboot shows the same issue.
Then I discovered the udevadm command, which initially seemed to enable detection of the dongle (although no use when dealing with internal hardware afaik).
I only mention it as a note right now as I’ve got more work to do in investigation and production of logs for diagnosis but it is a strange one for sure.
Thanks for the update.
BTW, this link to Mega was issued by a CE member (TheCoolest):
Looks like a test build just for you to test and chance, so that makes sense.
We unified the 3.14 and 4.9 AP6*** support now, so everything that worked on 3.14 should work on 4.9.
That includes AP6236.
Meaning from now on, like in the next nightly?
can i have link of nighty(k3pro?
its also not working:thinking:
Do older versions work or has it never worked for you?
Also post the output from this command:
udevadm info /sys/bus/sdio/devices/sdio* | paste
I have just tried 9.0.3 it works fine. With the command, i don’t know how to extract it,
Run the command over SSH (you can use PuTTY)
Then copy the URL it returns and post it.
