Hey guys,
is there a reliable bluetooth USB dongle which works with CoreElec out of the box? I’m using a mecool m8s pro + which doesnt have a built in bluetooth adapter
Hey guys,
Are you sure, are there multiple versions of the same box? At least according to some reviews like Android TV it should have built-in BT.
There’s an option to enable/disable BT under Addons / CoreELEC Configuration / Services.
There are some wrong information on this site. On the first picture and in the video you can see a M8S Pro Plus, but the technical information below are about the M8S Pro and M8S Pro L.
