Kodi shows subtitle on my Videofile although it’s not correct, because generally I only activated forced subs in player options.
Format : VobSub
Muxing-Modus : zlib
Codec-ID : S_VOBSUB
Codec-ID/Info : Picture based Default : Nein Forced : Nein
complete mediainfo:https://pastebin.com/JvbyU4e0
Crazy: It’s furthermore not possible to deactivate it, Estuary does not find any subtitle on this file (!?)
System: CE 8.95.7
If you have run it through MKVtoolnix, which it looks like you have, & you only ticked audio & video, then I suspect the subs are embedded, & as far as I know, there is no way to remove embedded subs.
I dont know very much about subtitles, so what does “embedded subs” mean? -> “Embedded” in the mkv-container? In that case: I have many mkv-files within forced flagged srt or ass subs - and I am able to deactivate them if I want.
But the other way round - vod subtitles that are not forced flagged (like mediainfo here) - are handled like forced and furthermore without a way to deactivate!? This sounds like a faulty behavior from kodi to me. Or is the problem founded in vod format?
I have no explanation. I searched for embedded subs, all I got was hard core encoded. But I don’t see them as the same.
If for example, a newly released movie, was downloaded over the internet, you could find there is for example chinese text. ( I am not saying you downloaded any movie)
you could run it through mkvtoolnix, it would not show the subs as a separate file, so you wouldn’t be able to remove them, as they would be embedded.
I do not know any way of removing embedded subs. You could try Handbrake.
Sorry I can’t be any more help.
as an aside, there is a website called subscene where you can download subs for different languages for different movies https://subscene.com
I have got subs from here & edited them, mainly for foreign parts only. Then using Mkvtoolnix added them to a movie, if I then reloaded it, it wouldn’t show as a separate sub.
I don’t think I have really answered your question.
Ah, I call this hardcoded or burned (dont know if its right), but we also can call it embedded But no, that is not the case, there is no hardcoded/embedded/burned subtitle in the videostream, it’s a seperated vod file in the mkv-container, that is flagged as not forced but handled as a forced subtitle and furthermore without possibility to deactivate.
That is a Kodi bug, not CE. We can’t really help with that.
I suggest you try it with Desktop Kodi and see if you can reproduce it, then open a case on Kodi’s support.
