Hello . in the latest CoreElec 8.90.5 the remote contr. does not work . the OLD box KII pro S905
I don’t know what GoreElec or C ELEC are, or why the remote contr. does not work on your OLD box.
But you could read the first thread in the “Remote Controllers” section, or this one:
https://discourse.coreelec.org/t/how-to-configure-ir-remote-control/
to find out how to get it to work.
thanks , The problem was in the file dtb.img
Now it works normally after you merge the file dtb.img
You don’t actually merge dtb.img files (just select the correct one) but, glad to hear you’ve managed to correct your mistake.
#pebkac strikes again
