Hi, i just got an Argon IR remote to use with my N2 running CE, thinking that the N2 has an IR port.
Turns out that while they provide a LibreELEC addon to drive the remote (cf. docs) that addon relies on rpi-tools which isn’t available on CoreElec (or at least not on my N2).
Is there any way to either get the rpi-tools (and even then, would they even do what they are supposed to on a N2?) or to maybe load the IR remote’s profile on its own?
For what it’s worth, i tried to remove the dependency to rpi-tools in the addon’s xml description, but it just fails when they Python code tries to import RPi.GPIO.
Any clues welcome!
