CE-22 NO: Looking for users with no working WiFi or BT
Please boot to Android and get the Android dmesg and share the log. If done boot again to CE and enable tmate so we can take a look by remote session:
https://wiki.coreelec.org/coreelec:term_share#establish_a_support_session
android dmesg.txt (262.1 KB)
Invitation has been sent
@Portisch
May I ask if you have already processed it? I have already enabled remote sharing.
CoreELEC
https://coreelec.org
CoreELEC (official): 21.0-Omega_nightly_20240413 (Amlogic-ne.aarch64)
      Machine model: Amlogic
     CoreELEC dt-id: sc2_s905x4_kinhank_g1
CoreELEC:~ # dmesg | paste
https://paste.coreelec.org/RoSItS
CoreELEC:~ #
Your logs do not bring us forward. You need to have and keep the device online with tmate. It’s not always we have a time to take a look so it can take hours or days until we find a free time slot. Right now there was one but the device is not online anymore…
Is it convenient to view remotely now?
A post was merged into an existing topic: Looking for users with no working WiFi or BT
@tht you can hard reboot your tht-2 device. I see no way right now without hardware to solve this driver. I will check what I can find here…
Done tht-2 has been rebooted
As far as Hardware Goes, I will send you tht-2 device and one of the s905x3 with the MT7668RSN wifi chipset
tht-2 —> Transspeed X3 s905x3 4gb/32gb gigbit ethernet wifi not working ethernet not working either
A95X F3 Air s905x3 4gb/64 wifi not working MT7668RSN
The Question I have is where do I send them?
X96 x10 Pro s928x-j 8/64
Clean install NE 12/31 5.4. 210 kernel
All working
Dmesg
https://paste.coreelec.org/PrevailOffice
Udev
https://paste.coreelec.org/MockeryTalents
Lspci
https://paste.coreelec.org/GustavArrives
Clean install NO 12/31 5.15.137 kernel
Ethernet/Bluetooth all good
No wifi
Dmesg
https://paste.coreelec.org/EnterDorian
Udev
https://paste.coreelec.org/InboundBeetle
Lspci
https://paste.coreelec.org/TroublesHolier
Latest Nightly 22 NO from Jan 3 2025
Has solved issues with wifi
Thx Team CoreELEC
Vontar X4:
Bluetooth works, wifi doesn’t.
WiFi works well with NG and NE.
I don’t know, did I do it right?
CE NO 20250108
Unfortunately, Youtube does not work again in this version. (The last working YT version was 20241220)
SDIO Wifi SoC:
https://paste.coreelec.org/StolenDestiny
USB Wifi SoC:
https://paste.coreelec.org/WheeledLovejoy
PCI Wifi SoC:
https://paste.coreelec.org/EmptyPaste
7:
https://paste.coreelec.org/MichelShoulder
Wifi chip is currently not supported:
We still have no hardware to test.
Thank you very much.
It works under NG and NE, unfortunately NG does not handle interlace video. And NE is unstable. There is no passthrough sound when first switched on, and I often get Safe mode with other models (Tanix x4, Vontar X4 and X96 max ultra)
I don’t know what to use on the X4 box.
NO does not handle accented letters well and Youtube often does not work
. :frowning:
https://paste.coreelec.org/PacifierIntimacy
Here is my Log Portisch .
Hope you can help me solving the Bluetooth issue.
I am on 21.2 stable Ne Omega. Freshly installed.
On Android Tv Os side Bluetooth works. In CE i can’t get it working.
Which chip is installed in my box and which Bluetooth dongle can you recommend?
