As I’ve started contributing to CoreELEC and gradually increasing the scope of changes and enhancements that I would like to make, it became clear that some of these changes need larger testing and validation before opening PRs into CE. Enter my CE Canary builds.
Canary builds are unofficial test builds of larger features and changes for CoreELEC that need wider testing before they can merge.
Each build is a CoreELEC nightly with our changes on top. Builds strictly follow the nightlies, and everything here is meant to go upstream to Kodi or be merged into CoreELEC. Once a change lands, it leaves the canary. When all features leave the canary, there may no longer be an active canary build and I will update the description accordingly.
Current testflights
- Blu-ray menu playback: full disc menus with more seamless clip transitions.
- A/V sync: vastly tighter audio and video sync with stability across playback events.
- Screen capture: screenshots and Hyperion ambilight for all HDR formats and output modes, even TV-led Dolby Vision, including Profile 5 and FEL.
Getting it
Downloads, install steps and setup notes for each feature are on GitHub:
Canary builds update an existing CoreELEC install, and you can go back to a normal nightly at any time. After the first install, new canary builds show up in CoreELEC’s normal Updates page.
Credits
The Blu-ray menu and A/V sync work draws on SamuriHL’s public builds and branches. His commits showed several of the defects, mechanisms and design ideas used here, and he reached a number of these problems first.
Reporting a problem
These are early feature previews. Despite extensive testing, there may be unexpected issues on devices outside my test coverage.
First, go back to a standard nightly and see if the problem is still there. If it is, it isn’t from the canary, so report it to CoreELEC as usual. If it only happens on the canary, report it in this thread. Features that only work on the canary can skip this step.
Follow CoreELEC’s guide to reporting an issue and debug log instructions. Then post in this thread or open an issue with your device, the build name, the steps and the link to your log. Since they may come from a change that isn’t in standard CoreELEC yet, please report them here rather than in any other threads.
Changelog
Each build’s changes are on the Releases page. New builds show up in CoreELEC’s Updates page, and I’ll post in this thread when one is out. To get notified on GitHub, use Watch > Custom > Releases on the repo.
Known issues
