Hello together, i have no problems before, but after the update to v8.90.5 i found some bugs 1st time sofar.
My Hardware
Bqeel M9Cmax / Amlogic 905X SOC, 2GB Ram - 16GB Rom.
Hartinstalled (on rom) v8.90.5 the 905 version.
Autoupdates 3 times since rom install. (nice function btw)
Bugs!
After the boot, on the Kodi mainscreen sometimes comes an error message like no connection to updateserver or so, thinks it needs more delay time for Wlan, after the start. i test after this message Youtube and it works. Updatecheck to fast?
Options/CoreElec/About, the screen is empty and it hangs, go to a other screen like system not helps, its empty too, you need to press often / ten times on âbackâ to go out from CoreElec, back to the option section, after this the speed/reaction of the box gone back normal. This Problem was never before x.x.x.4 etc. only by the newst version.
I love coreelec thx for this and your great work!!
The first bug is actually already fixed for the next version by enabling âwait for network before starting kodiâ in CE-settings. You are right in that it is a race condition but as soon as the network connection is active it restarts the remote communication server anyway so there is no issue for the end user other than the message.
As for the second bug report there is a delay whilst wireless networks are scanned, this is normal behaviour.
Scrolling down and up the list on the left (System, Network, Connections âŚ) initially shows the content of each on the right pane, but the right pane is blank on attempting to view each after the first time.
The detail does show after some time (maybe 20 secs).
I use a mouse to highlight the items on the left pane, in case this has any significance.
It is not possible to leave that page until the items re-populate (it apparently hangs).
I think that this happens when you go over Network, it can sometimes take time for the wireless networks to appear. It stops responding and the right pane remains blank until it finishes retrieving the network list.
The trouble is that âone manâs fix is another manâs bugâ and, if there was a manual refresh button, there will, undoubtedly, be those that donâ't use / see / know about it, and complain that something is broken.
Yes I know that it is not easy to cover all needs/requirements.
TBH, those few would be easier to deal with than any other scheme proposed so far, including the present one where the whole GUI locks up when the Network entry is highlighted.
The ârefreshâ could be incorporated into the heading, so that it refreshed only when clicked; or a separate button could be used. Making the âbuttonâ obvious should not be difficult, regardless its position.
Disabling wireless when wired is connected is a kludge IMO.
Yes it solves the GUI problem but it removes functionality, which is unnecessary when there are other solutions possible.
But whatever is decided I will live with.
Unless opinions are posted how can the devs know what users think?
TBH, I donât quite follow why it is necessary to have WiFi enabled if you have an active eth connection anyhow. Perhaps my usage of these devices is much simpler than others?
Anyway, weâve drifted into a discussion about a feature request now, so letâs pull it back on topic.
I donât see how itâs a kludge? This is the same behaviour in LE and will not be changed, itâs set this way so networks are listed during initial setup.
If you donât want the hang in the add-on then disable wireless, itâs really quite simple, there is nothing wrong other than peoples pedantrics and being anal and fussy over absolutely nothing, we have more important issues to deal with than this⌠seriously people?
âadamg, post:15, topic:1077â
OK, so you are dependent on LE for that behaviour. Just because LE does it, does not mean it is optimal or not though.
I have no doubt there are more important things you need to deal with but nobody is clamouring for immediate attention to this.
I do not think it unreasonable, pedantic, anal or fussy to expect both NICs to be able to work at one time, unless it is a hardware limitation. Obviously you disagree.
