Hi CE team. I can’t compile Coreelec for rockchip.
I get error:
/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8/v4l/ivtvfb.c:352:44: error: macro “access_ok” requires 3 arguments, but only 2 given
if (!access_ok(source + dest_offset, count)) {
/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8/v4l/ivtvfb.c:352:7: error: ‘access_ok’ undeclared (first use in this function)
/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8/v4l/ivtvfb.c:352:7: note: each undeclared identifier is reported only once for each function it appears in
make[4]: *** [scripts/Makefile.build:284: /home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8/v4l/ivtvfb.o] Ошибка 1
make[4]: *** Ожидание завершения заданий…
make[3]: *** [Makefile:1468: module/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8/v4l] Error 2
make[3]: Leaving directory ‘/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/linux-aa8bacf821e5c8ae6dd8cae8d64011c741659945’
make[2]: *** [Makefile:53: default] Error 2
make[2]: Leaving directory ‘/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8/v4l’
make[1]: *** [Makefile:26: all] Error 2
make[1]: Leaving directory ‘/home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/dvb-latest-0f25e6fb13b6bc345218800ad9ac863deb2ee9c8’
FAILURE: scripts/install dvb-latest has failed!
[087/251] [FAIL] install dvb-latest
The following logs for this failure are available:
stdout: /home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/.threads/logs/77/stdout
stderr: /home/code/CoreELEC/build.CoreELEC-RK3399.arm-9.2-devel/.threads/logs/77/stderr
parallel: This job failed:
package_worker 3 77 251 ‘install dvb-latest’
Parallel build failure - see log for details. Time of failure: Tue Sep 17 07:56:28 EET 2019
Makefile:12: recipe for target ‘image’ failed
make: *** [image] Error 1
How to fix?
