Hello.
I have a Coreelec on the TV box and an external drive connected to USB 3.0. The box is wired to the router as well as the PC. I would like to configure the Box and PC so that the Box is accessible from the PC. So to copy files from PC to external disk box. I would do this from a PC. I can’t configure my computer and Box. I tried the guides. Can anyone give detailed instructions?
This works out of the box, when you have enabled SMB/Samba.
CoreElec Config - Services - Samba - check enable Samba.
is enabled, how configured pc?
No config necessary. Just enter IP of your box or coreelec in windows explorer address bar. That’s it.
