I don’t know, but why don’t you just try them, you can easily overwrite existing ones.
I use Coreftp lite to copy files on my boxes from my win 10 pc
I see you have asked a similar question on the Libreelec forum. You could try blue tooth, I use blue tooth in Coreelec with my headphones, you could try it.
I use the latest version of CoreElec for sure. But that is strange, i will test it again later. On the other hand it works now, why should i change it? I am not sure. Perhaps the IR Remote of the MeCool M8S Pro L works out of the box with CE? I did not change anything else there.
Hi!
I also have Xtreamer Whizz with Libreelec S905.arm-8.2-8.2.3.1, but I can’t get my remote to work. I have tried with your remote.confg, but no success.
I don’t have much experience in such programing, so some help would be appreciated.
Could you help me?
Regards
I try it but didn’t work for me.
I
Copy elite to /storage/.config/rc_keymaps
Copy rc_maps.cfg to /storage/.config
I reboot
I choose minix u9 on my harmony
but keys have no action
