Read these post
with putty
ir-keytable -t
you can press a button on romote and see the code.
insert this into the file or replace a code. repeat the activation procedure and you must be good to go
On MINIX forum I have example
Read these post
with putty
ir-keytable -t
Hi I have reposted the beelink_W95 as I had a moment when I posted the origonal and forgot to add the second file.beelink_W95.zip (1003 Bytes)
does anyone know how to remove all the remote files and revert back to an original state without having to do a fresh install?
If you mean you have installed a file and now the built in ones are not working I just removed rc_maps.cfg you can remove the files you added from rc_keymaps folder.
Mecool m8s pro L box, i have tried a few of the remote configs and i canât get any to work. i donât think i am dong it wrong can someone advise. downloaded the m8s.zip, km8pro.zip, mecool k1 pro.zip, and M8SPro+ i extracted the 2 files and placed in the folders then rebooted.
Thank you
cancel this, i fixed this by doing thie cmd below
in putty: echo âmeson-ir * mecoolâ > /storage/.config/rc_maps.cfg
Thank you!
SirďźI have a remote files .config of KI Plus box.
Please share it with anybody.
thank you.
download link :
done, but renamed to KI plus to avoid confusion with other files
Thank you so much.
Can you build a index for boxâs name in your topic ?
It wounld help other people to find their boxâs file so fast.
Iâm not sure that an Index is really needed. There are only about 20 files.
Everyone should be able to access the folder
Note sure if anyone is interested in the old Nexbox A1, but I have a working rc_maps.cfg + rc_keymaps
Iâm not allowed to upload files as a new user, so Iâll post the contents.
File ârc_maps.cfgâ:
# Keymaps table
# This table creates an association between a keycode file and a kernel
# driver. It can be used to automatically override a keycode definition.
# Format:
# driver - name of the driver provided via uevent - use * for any driver
# table - RC keymap table, provided via uevent - use * for any table
# file - file name. If directory is not specified, it is first looked up
# in /storage/.config/rc_keymaps, then /usr/lib/udev/rc_keymaps
# For example:
# driver table file
# gpio-rc-recv rc-streamzap streamzap
# gpio-rc-recv * justboom
# * rc-rc6-mce rc6_mce_new
# * * hauppauge_new
meson-ir * nexboxa1
File called ânexboxa1â placed in rc_keymaps :
# table nexboxa1, type: NEC
0xdf54 KEY_1
0xdf16 KEY_2
0xdf15 KEY_3
0xdf50 KEY_4
0xdf12 KEY_5
0xdf11 KEY_6
0xdf4c KEY_7
0xdf0e KEY_8
0xdf0d KEY_9
0xdf0c KEY_0
0xdf18 KEY_MENU
0xdf5d KEY_VOLUMEUP
0xdf5c KEY_VOLUMEDOWN
0xdf42 KEY_HOME
0xdf07 KEY_RIGHT
0xdf47 KEY_LEFT
0xdf1a KEY_UP
0xdf48 KEY_DOWN
0xdf06 KEY_ENTER
0xdff3 KEY_MUTE
0xdf0a KEY_BACK
0xdf03 KEY_INFO
0xdf4b KEY_PREVIOUSSONG
0xdf4f KEY_NEXTSONG
0xdf1c KEY_POWER
0xdf01 KEY_PLAYPAUSE
0xdff2 KEY_EPG
Using CoreELEC-S912.arm-9.0-nightly_20190102-S912.img.gz
Edit: Now I can uploadâŚhere they are.
nexboxa1 (457 Bytes)
rc_maps.cfg (762 Bytes)
Hereis my combined remote file it does X96, W95, A95X and magicsee N5
combined (2.2 KB)
rc_maps.cfg (779 Bytes)
The keys for the magicsee N5 are
0x40404d KEY_POWER
0x404045 KEY_MENU
0x40401a KEY_HOME
0x40400b KEY_UP
0x404010 KEY_LEFT
0x40400d KEY_ENTER
0x404011 KEY_RIGHT
0x40400e KEY_DOWN
0x404042 KEY_BACK
0x40401c KEY_VOLUMEDOWN
0x404015 KEY_VOLUMEUP
0x404044 KEY_CONTEXT_MENU # mouse
Polite request to all. If you create a new remote set, please add both the config file & the keymap, then zip them up. If there is a similar named one in Dropbox, just rename it.
I think I have left the dropbox so, you should be able to upload them yourselves. (I think)
I now have a nvidia shield, so I donât spend as much time playing around as I did.
0x0051 KEY_ESC
0x0052 KEY_1
0x0050 KEY_2
0x0010 KEY_3
0x0056 KEY_4
0x0054 KEY_5
0x0014 KEY_6
0x004e KEY_7
0x004c KEY_8
0x000c KEY_9
0x000f KEY_0
0x001a KEY_ENTER
0x000d KEY_HOME
0x0006 KEY_UP
0x005a KEY_LEFT
0x001b KEY_RIGHT
0x0016 KEY_DOWN
0x0019 KEY_MUTE
0x0017 KEY_VOLUMEDOWN
0x0013 KEY_VOLUMEUP
0x0059 KEY_POWER
0x0045 KEY_MENU
0x0005 KEY_BACK
0x000b KEY_NEXTSONG
0x0008 KEY_PREVIOUSSONG
0x0022 KEY_TEXT
0x0018 KEY_CONTEXT_MENU
please read my previous post. Create the files zip & upload
thanks
Hi adam,
for simplification, convenience and better overview, one could also use the following command at this point.
irrecord -l
or
irrecord -l | paste
output
Thank you for your tireless work!
Best Regards
How to use IR remote configurations which is built into coreelec (a95x)? I mean to say that when ones write image into sd card and card plug into andriod box (a95x box) and after installation where is built in remote configuration location or procedure?
Could you please also add a config for pivos xios ds, since a popular FAQ (am I allowed to link to the LE board? If not, please delete my link) on the libreelec board suggest to map the harmony remote according to this device to have a lot useable buttons and function to chose from.
I (and probably a lot others who have found the FAQ) have set up all my AMlogic devices and harmony remotes according to this FAQ and an already included build-in config would allow users to set up their harmony remotes without having to add another remote.conf.
I would love to see that, since I am planning to update from LE to CE with the first RC/stable leia build of Kodi.
