@erbas I just tried it with a different MCE type remote on a fresh install and it worked on my meecool box without rc_maps.cnf. I did not need the receiver plugged in.
Great news
Eager to test.
Thank you, friend, soon post result!
@ffimon
Just like you said, you did not have to do anything, it just works.
Very fast, excellent alternative!
I had this control saved for 10 years.
Given as lost.
Need only make a few adjustments the power button just delays the box
Youâre perfect!
Thank you.
You wont be able to use that remote to turn the box on only the original one will do that. I Never turn mine off you only save about 4W by turning it off
WIWA Dream Player
# table WIWADream, type: NEC
0x59 KEY_POWER
0x08 KEY_PREVIOUSSONG
0x0b KEY_NEXTSONG
0x18 KEY_TEXT # KEY_PLANET
0x46 KEY_PLAYPAUSE
0x13 KEY_VOLUMEUP
0x17 KEY_VOLUMEDOWN
0x0d KEY_HOME
0x05 KEY_BACK
0x06 KEY_UP
0x5a KEY_LEFT
0x1b KEY_RIGHT
0x1a KEY_ENTER
0x16 KEY_DOWN
0x45 KEY_MENU
0x12 KEY_CONTEXT_MENU # KEY_MOUSE
0x52 KEY_1
0x50 KEY_2
0x10 KEY_3
0x56 KEY_4
0x54 KEY_5
0x14 KEY_6
0x4e KEY_7
0x4c KEY_8
0x0c KEY_9
0x0f KEY_0
0x22 KEY_INFO
0x51 KEY_ESC
Uploaded, Thanks
One filename in MS8Pro+.7z is wrong. It reads MS8Pro_ instead of MS8Pro+
Thanks a lot for maintaining this by the way !
Renamed, thanks fr fedback
good to know, ps4 controller work like a harm as well! just connect with usb on me h96 pro+ press the ps4 main button, wait few seconds and then unplug. Bluetooth stay connect and working perfect
uploadedâŚ
This is an odd one and not sure if appropriate, but this remote (Philips RC122) is used by major US cable service providers. If you have cable TV like I do and want to control your Kodi box with its remote here are the codes;
Program the desired function button with code 2054 per the remote manual (I use the VCR button); https://d15yx0mnc9teae.cloudfront.net/sites/default/files/sup_remote-manual_philips-rc122-twc.pdf
For wake from IR;
remotewakeup=â0xed12ba45â
# table rc122, type: NEC
0x4512 KEY_POWER
0x45b2 KEY_INFO #INFO
0x4584 KEY_CONTEXT_MENU #MENU
0x4522 KEY_BACK #EXIT
0x4521 KEY_ENTER #SELECT
0x4580 KEY_UP
0x454d KEY_RIGHT
0x4581 KEY_DOWN
0x4551 KEY_LEFT
0x4515 KEY_PLAY
0x4514 KEY_STOP
0x4500 KEY_PAUSE
0x4519 KEY_REWIND
0x4513 KEY_FASTFORWARD
When I clicked the download link for WIWADreamPlayer.zip, it took me to a premium site asking me to pay for registering a new premium account in order to download the file. Can you please provide a non-premium link for us to download the file?
I already tried that (the link is shown below) and it still takes me to the premium site asking me to register for a paid premium account, unfortunately.
I meant that miszel can simply attach the file to the forum, instead of linking to some weird hosting websites.
Oh IC. Sorry about that.
I canât seem to get my T95M remote to work. I used to just dump remote.conf into the ~/.config dir and away I went with libreelecâŚ
Here is a copy of what I use.
I tried the rc_map.cfg and T95M from for drop box, but they did nothing for me.
remote.conf: https://pastebin.com/ATAtsPzC
Anything else I could try to get this wokring?
Run remoteinfo
in SSH and paste the link it spits out so we can see the log.
