CoreELEC fail to fetch addon repository
After the latest nightly was downloaded, I no longer get the cannot connect error. Now I get a new error and all attempts to download from kodi repo fails. Other repos like coreelec work fine.
https://paste.kodi.tv/xeladoxuco.kodi
Guessing this is the error, whatever that means: error : Could not find suitable input format: x-directory/normal
Please enable DEBUG in Kodi logging.
Now in Omega RC1. Same issue
https://paste.kodi.tv/ekoqufibez.kodi
Please try again, it should be solved now. Again.
Hi, the issue seems to be still there. I just did a clean install of CoreElec 20.5 (SXS905X4) and all Addon Updates/Install from the Official Kodi Repository fail.
https://paste.kodi.tv/hacejemobu.kodi
Yes, still an issue. Looks like it will take little more to fix.
It is fixed. Again :slight_smile:
Yes it is :+1: Thank’s for your work :grin:
Yes, works now, thank you.
Thank’s a lot, @vpeter , it works :grinning: :+1:
