zeeya
6 November 2021 03:55
1
CoreELEC always freezes when left idle after switching on, Leaving the system on for about 20 to 30 minutes.
Hardware:
Ugoos AM6B PLUS
Software:
CoreELEC 19.3 Matrix
No problem when it is playing a movie.
What might be causing the issue? Please help.
Atreyu
6 November 2021 07:48
2
Try and recreate the issue with debugging enabled and post the crash log. Without it, it will only be a guessing game.
zeeya
6 November 2021 15:37
3
Make a complete clean install without any addon and try again. It’s 100% some addon/repo you have installed cause this issue.
Atreyu
7 November 2021 08:18
5
Yes, please do try with a clean install. After that, you might start adding one by one to see which one is starting trouble. Good luck!
system
Closed
6 February 2022 14:19
6
