CoreELEC with IPTV Archive support
#41
@klazarev
I don’t understand what you mean. Please post a screenshot.
@netbuild
This is not possible, it is built into the skin, just like a recording or a timer icons are, and Estuary doesn’t have any configuration settings I could add a toggle for it to.
If it really bothers you that much, you can manually download and install the estuary skin from the Kodi repository.
#42
Unlike the screenshot above, I don’t display information about past broadcasts. In the file edem.xmltv.gz this information is
#43
You can skip forward and then back with the arrow buttons on your remote/keyboard.
#44
The “<” button brings up the Options side menu, and the “<<” button only moves the program to the beginning of the current program. How can I see, for example, yesterday’s program?
#45
This is a Kodi thing, maybe something with your PVR & LiveTV settings for the EPG is wrong. This has nothing to do with Edem nor the IPTV Archive feature.
If you first go forward ( > ), then going back ( < ) should work.
#46
Thank! It was in the EPG settings that there was a reason
#47
So does anyone know the url format for rapid? https://iptv.community
#48
If this service works with OTTPlayer, and archive works in it then the format should be ?utc={utc}&lutc={lutc}
#49
If i do that and click on a past programme on channel with archive (at least xtreme-editor shows it has archive) it still play current programme
#50
Can you PM me a part of your playlist? You can redact the URL parts, maybe there’s something that will help.
#51
https://pastebin.com/raw/gg38xHyN
#52
Sadly that doesn’t provide any info on how to access their archive.
#53
Hi I have playlists that work in perfect player but can not figure out how to get them to work in Kodi. Do you have any experience with perfect player?
#54
Which archive type are you using with perfect player?
#55
catchup=“xc”
#56
Can you PM me a small part of your playlist, with channels that support archive and channels that don’t (if there are such).
You can filter out username\password\IDs\etc. I just need to look at the structure of the playlist to see if support for it can be added.
#57
It looks like the playlists have no reference to catch up or sources other then in the header with the catchup=“xc” tag. But after doing some digging on how the providers add on provides the catch up streams i have found that they use a slightly altered url -
%s:%s/streaming/timeshift.php?username=%s&password=%s&stream=%s&start=%s&duration=%s
But this is where I am stuck atm cheers
#58
What is %s:%s before the rest of the URL?
How does a normal URL look like?
#59
Host address and host port. E.g http://iptv.com:83
#60
We keep going back and forth, sorry, this isn’t going to work.
Please send me the full info in a PM, it doesn’t have to be on the open forum. I don’t need your user/pass, but I need the full URLs to understand how it works, and see if anything can be done to add support for this IPTV service.
