Duration and start time are freely editable.
The first issue is there is no placeholder for duration.
2nd is Our timeshift is not a PHP variable, it’s an entirely different URL.
I don’t suppose you have any ideas how we can get around this?
I’m sure you can “hardcode” the duration at something like 3600 (seconds).
For the “start time”, you can use the placeholders describing in the first post of this thread, depending on the time format your provider requires.
You can’t, you’ll need to edit your playlist and add a catchup-source info tag for every channel that supports archive. See the first post under limitations.
It appears that many providers are using XC as their panel platform. Along with this, not many of them really “know” how to support these functions, little alone, kodi. The standing solution across the board is to use Simple Client and it is what it is.
However, users are able to query the servers and obtain JSON info just the same as the various IPTV apps on the market.
This brings a question and potentially a question to light.
Wouldn’t it be easier to fetch the JSON and then pass that over to the desired locations?
i.e.
for regular LiveTV: fetch JSON, parse, pass over to Simple Archive as a cached m3u8
for catchup TV : fetch JSON, interpret, pass over interpretations to Simple Archive
for VOD: fetch JSON, parse, import to Video Library (Movies)
for Series: fetch JSON, parse, import to Video Library (TV Shows)
From what I have gathered across multiple communities, this would be the practical approach, and would provide users the same experience that the various IPTV apps give.
Ok, I want to look how difficult would be to add XC archive support, as I can see, rest calls are pretty simple, problem is I don’t know anything about kodi addon api internals and my Python knowledge is rather limited
Archive works, no complains. Worka stable. But there is big issue ‘forward’ ‘back’ ‘pause’ buttons greyed out, can’t skip commercials then watching something from archive.
Can you test this one? It adds support for the offset placeholder. The syntax is as follows: {offset:X} - where X is the divider.
If you need an offset of 720 for 2 hours (2 hours is 7200 seconds), it means your divider is 10.
In that case you’ll need to replace X with 10: {offset:10}.
The minimum divider is 1, it must be an integer (not 1.5 or 2.25 etc.), it must be a positive value.
