Been using the N2 for a couple of months now with the nightlies and over the last couple of weeks I have noticed regular crash logs about everyday or two. Also happened this morning on version 9.0.3.
The odd thing is it happens when the N2 is not being used, like in the early hours of the morning. Take the one for this morning at 8:03AM when the N2 was not being used and was last used at 20:44 the night before.
It looks like some PVR related issue…
May be some epg update or something related… Check that you don’t have non-working links in PVR/EPG settings somewhere
It’s kodi or addons related - 100%
In crash dump I see
#11 0x00477048 in PVR::CPVRGUIInfo::UpdateQualityData() ()
#12 0x004771f0 in PVR::CPVRGUIInfo::Process() ()
Now assumptions:
So it possible somehow related to PVR
I know that kodi can crash if he stuck on EPG update, I had this issue…
And it looks like some scheduled action. if you don’t use box at this time.
So this is not 100% the reason, but as something to check…
No, it looks like kodi issue, not system…
Could you also upload full log?
go to smb share and upload file \IP\Logfiles\ and upload latest file (after kodi crash and no system reboot)
Unfortunately I’m still getting the random crashes when not using the N2 since updating the the recent nightly, that includes 18.4. I suspect, have no proof, it has something to do with TvH and maybe the epg updates that happen every two hours.
