additional information from log (when playing DTS 7.1 movie):
> 2021-12-28 12:19:44.116 T:4051694400 INFO: CActiveAESink::OpenSink - initialize sink
> 2021-12-28 12:19:44.168 T:4051694400 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:@:CARD=USBStreamer,DEV=0
> 2021-12-28 12:19:44.175 T:4051694400 INFO: CAESinkALSA::Initialize - Requested layout: FL, FR, FC, LFE, BL, BR, SL, SR
> 2021-12-28 12:19:44.175 T:4051694400 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=USBStreamer,DEV=0"
> 2021-12-28 12:19:44.194 T:4051694400 INFO: CAESinkALSA::Initialize - Opened device "surround71:CARD=USBStreamer,DEV=0"
> 2021-12-28 12:19:44.196 T:4051694400 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
> 2021-12-28 12:19:44.196 T:4051694400 ERROR: CAESinkALSA::InitializeHW - Unable to find a suitable output format
> 2021-12-28 12:19:44.197 T:4051694400 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:default
> 2021-12-28 12:19:44.197 T:4051694400 INFO: CAESinkALSA::Initialize - Requested layout: FL, FR, FC, LFE, BL, BR, SL, SR
> 2021-12-28 12:19:44.197 T:4051694400 INFO: CAESinkALSA::Initialize - Attempting to open device "default"
> 2021-12-28 12:19:44.215 T:4051694400 INFO: CAESinkALSA::Initialize - Opened device "default"
> 2021-12-28 12:19:44.225 T:4051694400 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
> 2021-12-28 12:19:44.226 T:4051694400 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
> 2021-12-28 12:19:44.226 T:4051694400 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 16384
> 2021-12-28 12:19:44.246 T:3902796608 DEBUG: CVideoPlayer::ProcessVideoData size:482 dts:0.250 pts:0.667 dur:41.000ms, clock:-0.333 level:0
> 2021-12-28 12:19:44.246 T:3902796608 DEBUG: CVideoPlayer::ProcessVideoData size:479 dts:0.292 pts:0.501 dur:41.000ms, clock:-0.333 level:0
> 2021-12-28 12:19:44.246 T:3902796608 DEBUG: CVideoPlayer::ProcessVideoData size:478 dts:0.334 pts:0.417 dur:41.000ms, clock:-0.333 level:0
> 2021-12-28 12:19:44.246 T:3902796608 DEBUG: CVideoPlayer::ProcessVideoData size:479 dts:0.375 pts:0.375 dur:41.000ms, clock:-0.333 level:0
> 2021-12-28 12:19:44.246 T:3902796608 DEBUG: CVideoPlayer::ProcessVideoData size:478 dts:0.417 pts:0.459 dur:41.000ms, clock:-0.333 level:1
> 2021-12-28 12:19:44.256 T:3902796608 DEBUG: CVideoPlayer::ProcessVideoData size:478 dts:0.459 pts:0.584 dur:41.000ms, clock:-0.333 level:2
> 2021-12-28 12:19:44.256 T:4051694400 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 16384
> 2021-12-28 12:19:44.256 T:4051694400 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 342 ms
> 2021-12-28 12:19:44.257 T:4051694400 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 8 Output Channel Count: 8
> 2021-12-28 12:19:44.257 T:4051694400 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR, FC, LFE, BL, BR, SL, SR
> 2021-12-28 12:19:44.257 T:4051694400 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR, LFE, FC, SL, SR, BL, BR (ALSA: FL FR LFE FC RL RR RLC RRC) (CEA: 7)
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Output Device : Default (AML-M8AUDIO Analog)
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Sample Rate : 48000
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Sample Format : AE_FMT_S32NE
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Channel Count : 8
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Channel Layout: FL, FR, LFE, FC, SL, SR, BL, BR
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Frames : 2048
> 2021-12-28 12:19:44.258 T:4051694400 DEBUG: Frame Size : 32
the USB device is not supporting the requested format and KODI is switching to onboard sound card.
