Hi all,
Odroid N2 with CE 19.3.
I have an HDHR and I’m using it with TVH using IPTV and it’s been great. Some channels broadcast in MPEG-2 while others, usually the HD Channels, in MPEG-4.
Recently the MPEG-2 Channels have a much, I mean a lot, reduced volume compared to the MPEG-4 channels.
When using the HDHR Software on Windows 11 there is no such volume reduction.
Any ideas why I’m seeing the reduced volume on CE?
TIA
EDIT:
Below is the dispinfo output for a “normal” volume channel and a “reduced” volume channel.
Normal volume HD Channel - http://ix.io/4iuv
Low volume SD Channel - http://ix.io/4iux
Hope it helps.
