Maybe someone can help me here. I have a TCL tv with a CEC conection to a Nexbox A95X (s905x).
I am on coreelec version 9.2.1.
If I set the screen saver to dim (it does not dim at any % just turns off) or set Turn off via CEC with no video playing, the TV will turn off after the allotted time passes.
If I press the preview button in the screensaver settings, the TV will also turn off with either screen saver.
However if I have a video paused, the TV never turns off.
Under Turn off, I have tried “Use dim if paused during video playback” option enabled and disabled with no change either way.
Turn off used to work on previous version if I selected CEC as the method, and had the dim option disabled.
I can live with Dim not dimming, and just turning off if it did that while videos were playing.
Black screen saver does seem to work as expected while a video is paused. Unfortunately it does not turn off the tv if the video is paused. It does turn off the TV when I press the preview button or after the allotted time has passed which is kind of odd also.
Anyone have a suggestion of what I could try?
