Hi All,
Looking for some ideas on how to find why compile of latest Docker 19.03.8 as CoreELEC Kodi package/service fails.
Here is how it was done:
Docker version, SHA256 and patch to update paths has been updated to work for 19.03.08 and then run:
PROJECT=Amlogic-ng ARCH=aarch64 scripts/create_addon docker
The last command as it looks like which gets run is:
/home/builder/CoreELEC/build.CoreELEC-Amlogic-ng.aarch64-9.2-devel/toolchain/lib/golang/bin/go build -v -o bin/docker -a -tags 'daemon autogen exclude_graphdriver_devicemapper exclude_graphdriver_aufs exclude_graphdriver_btrfs journald' -ldflags '-w -linkmode external -extldflags -Wl,--unresolved-symbols=ignore-in-shared-libs -extld /home/builder/CoreELEC/build.CoreELEC-Amlogic-ng.aarch64-9.2-devel/toolchain/bin/aarch64-libreelec-linux-gnueabi-gcc -X '\''github.com/docker/cli/cli.Version=19.03.8'\'' -X '\''github.com/docker/cli/cli.GitCommit=19.03.8'\'' -X '\''github.com/docker/cli/cli.BuildTime=Mon Mar 23 01:31:15 UTC 2020'\''' ./components/cli/cmd/docker
Output stops at this:
... github.com/googleapis/gnostic/OpenAPIv2 github.com/hashicorp/golang-lru golang.org/x/oauth2/google k8s.io/apimachinery/pkg/util/cache k8s.io/client-go/util/jsonpath k8s.io/apimachinery/pkg/util/diff k8s.io/apimachinery/pkg/util/wait k8s.io/utils/trace github.com/docker/cli/cli/command/bundlefile github.com/docker/cli/cli/command/swarm/progress FAILURE: scripts/build docker has failed!
This is way after patch is applied and I’ve no idea why it fails.
On same system, earlier the default as defined within CoreELEC as latest: Docker 18.09.7 compiled without a hinch.
Any thoghts/suggestions are more than welcome.
p.s. Compilation is done on amd64 for aarch64.
