Using a fresh image (1556922614-Odroid_N2) I’m not able to open Docker addon.
I’ve been able to execute systemctl start service.system.docker.service, but when I want to open the addon nothing happens.
Any thoughts?
Any thoughts?
You need to install the addon and reboot, after that you can use Docker by SSHing into the box.
Docker is a command line tool.
You can’t open the add-on. This is a service add-on and works only from command line through ssh. You have to setup your containers using docker run command.
Thank you your help guys!
