Who will enjoy from this “perfect build” of NG 21? only few and lucky people?
Here it seems that the discussion is now among 3/4 people only.
I’m sure it will be shared, no need to worry.
nor worried, just to clarify
I dont know how others but I dont know how to compile the source code to img. Hence for me no other updates are relevant as the sdr to dv is the biggest leap in video encoding for me. It’s really frustrating as the overal skin/encoding/new features was so exciting. So many of us just ended up on latest A5 build without any other tweaks from CE team and @cpm .
The code is public and can be compiled by yourself if you have experience.
Currently this is the only one way.
“Repetita iuvant” Sorry If I use Latin proverb.
Maybe asking a stupid question, but is NG CPM the only CE version that can successfully decode FEL on the Ugoos?
I’ve read somewhere that the Ugoos will be supported in other CE versions, too, but does this mean is does not have all features?
Yes it will. Maybe not here on the CE forum but it will be available. He said it. Just be patient. I guess within 1 or 2 weeks , everybody will be happy again
This is the Guide:
https://wiki.coreelec.org/coreelec:build_ce
Prefered option is to use WSL if you are a windows user.
git clone https://github.com/CoreELEC/CoreELEC.git
cd CoreELEC
git checkout coreelec-21
This needs to be edited to get the sources from CPM:
projects/Amlogic-ce/packages/linux/package.mk
projects/Amlogic-ce/packages/mediacenter/kodi/package.mk
Then build with this command:
DEVICE=Amlogic-ng PROJECT=Amlogic-ce ARCH=ARM make
and media-modules is no longer needed as the changes have been a part of upstream for while.
so only two packages need adjustment.
I hope everyone will appreciate work needed even for some small change or feature more after this. By CE team or by any other dev.
will try, I tried yesterday but got stuck at some point, so hopefully will get there with your manual. Thanks a lot.
What needs to be edited in:
PKG_VERSION, PKG_SHA256 and PKG_URL must be edited.
package.mk (12.1 KB)
package.mk (18.9 KB)
Try this.
Note, however, that this is only intended for the current changes up to now. If CPM makes a change, these files must be edited again.
If anyone knows a better solution, please let us know.
Edit:
You may get an error in the build because of the json-c.
Change the SHA256 in the package.mk of the json-c to one of the two. (forget which one is the right one)
bca9a584a8da64d8dff50082a06f6cea26fb735f74924afc6d01ae6be7a75885
or
fc1b9ed57f4cda51c52ec9b3b012f6973bd8d80fb70f363c5ca2754342389eb1
There’s no better solution, just a different one if you want to base his changes on the latest Kodi from nightly CE (with cherry-picking his commits on the latest upstream Kodi, generating a patch and without the need to modify packages). Cpm described the procedure in one of his posts. That’s what I’m doing. Current branch of cpm’s code is based on a slightly bit older kodi version compared to upstream with a couple of newer changes backported. So using packages.mk you get fully what’s in his repo.
I don’t know how you get the URL as the cpm-code/xbmc/archive is not reachable… am I missing something ?
You must combine PKG_URL and PKG_VERSION:
https://github.com/cpm-code/xbmc/archive/a5d070267e169b7d5dd367fe17c43a2e77e3a90b.tar.gz
Replace the attached file with yours and done.
You don’t need to download it manually.
I know but I’m curious about how you get the PKG_VERSION if not from the URL. I mean I’m trying to find out how you get those codes.
I use Powershell with git to get the latest PKG_VERSION:
Paste and enter this:
$PKG_VERSION = git ls-remote https://github.com/cpm-code/xbmc.git HEAD | ForEach-Object { $_.Split("`t")[0] }
Then paste and enter this:
$PKG_VERSION
Then you got a result.
For SHA256 you can get a file calculator to get it or when the builds fails because of the wrong SHA256.
It makes perfect sense to me now. Thank you very much for explanation.
