hi i never succeed using CoreELEC 8.95.0 on k1 pro s905d 2gb
i’ve all dtbs on the /dtb dir but my box only hang up or reboot after bootscreen
pls anyone kind enough point me to the correct one
thanks in advance
thanks in advance
What’s 8.95.1 like ?
Which dtb.img file/s have you attempted to use (out of the /dtb directory)?
Don’t forget the dtb should be renamed to dtb.img and placed in the ROOT folder where SYSTEM and boot.img resides.
@JohnBoyz cant remember exactly the name, but ive tried it all
@anon88919003 yes i did rename as i’ve been following libreelec scene since day one kszaq releases
