E900V22C with S905X2
Thank you so much for your help! Wi-Fi now starts automatically after the device boots up, and I really hate to bother you again. However, I still encountered two issues during use and hope you can assist me when you have some free time.
  1. 5GHz Wi-Fi Connection Issue: The device cannot connect to 5GHz Wi-Fi when the router’s security mode is set to WPA3/WPA2. I only managed to connect to the 5GHz network after changing the router’s security mode from WPA3/WPA2 to WPA2/WPA, but the performance doesn’t seem ideal. I can confirm that this Wi-Fi chip supports the WPA3/WPA2 security mode on the Android platform.
  2. Bluetooth Device Detection Issue: The device’s Bluetooth can detect nearby devices, but all of them are audio output devices. It fails to detect my Bluetooth remote control and other input devices.
https://paste.coreelec.org/ChoppingVroom
If you need tmate for remote troubleshooting, I have it enabled, and the connection name is Freestyle.
Contact your vendor to provide a working, stable driver? This is out of our control.
Got it, I understand. Thank you so much indeed!
