Hi
(EDIT : i’m adding logs, with the issue happening around 13:17:16)
i’m using Odroid N2 and Coreelec for years. I’m using PCM multichannel for audio HD because my AVR (Denon 4306 with HDMI 1) is a fine 7.1 AVR but old. It worked flawlessly up to coreelec 18.
Since Coreelec 19 i have issue with some EAC3 tracks. I have sound cuts (about 1sec or less) or audio dropouts (don’t know how it’s best to call this). Some tracks do work fine, others have issues. Both use audio decoder ff-eac3. It seems that when the track is ATMOS, it works fine. I guess there’s some bug here because with coreelec 18 there’s not this issue. I’m surprised that i have never heard about this for months (people with old AVRs). It also seems to only happen if video is in UHD.
Here are some examples :
With issue :
Audio #3
Format : E-AC-3
Format/Info : Enhanced AC-3
Nom commercial : Dolby Digital Plus
Identifiant du codec : A_EAC3
Durée : 1 h 12 min
Type de débit : Constant
Débit : 640 kb/s
Canaux : 6 canaux
ChannelLayout : L R C LFE Ls Rs
Echantillonnage : 48,0 kHz
Images par seconde : 31,250 Im/s (1536 SPF)
Mode de compression : Avec perte
Taille du flux : 333 Mio (4%)
Langue : Anglais
ServiceKind/String : Complete Main
Default : Non
Forced : Non
No issue :
Audio #2
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Nom commercial : Dolby Digital Plus with Dolby Atmos
Durée : 52 min 26s
Débit : 768 kb/s
Canaux : 6 canaux
Taille du flux : 288 Mio (20%)
Titre : VO E-AC3 Atmos 5.1 @768kbps
Langue : Anglais
Default : Non
Forced : Non
ComplexityIndex : 16
NumberOfDynamicObjects : 15
BedChannelCount/String : 1 canal
BedChannelConfiguration : LFE
Any advice how to debug this ? should i post on a KODI forum ? Is it possible to tweak the audio decoder ?
PS : VPETER : if you read me you might me one of my greatest hope to solve this
PPS : i still have to test coreelec 20 but i’m not confident since no one talks about this.
Regds
kodi.log (8.9 MB)
