bam
10 October 2019 18:55
#1
I have relatively long release_delay=200
in remote.conf
Actual delay occasionally happens even bigger - >400msec, causing Kodi to register double-presses on single key press.
Why is that?
#amlogic NEC remote
factory_code = 0x79840001
work_mode = 0
repeat_enable = 1
#repeat_delay = 130
repeat_delay = 50
repeat_peroid = 120
release_delay = 200
debug_enable = 1
@anon88919003
same problem here - at the moment i use kore on my tablet to workaround this
bam
11 October 2019 02:35
#3
Working zone for the delay seem to be very narrow for me, <40ms:
110 < release_delay
< 150
you can try this settings
repeat_delay = 120
repeat_peroid = 33
release_delay = 121
bam
11 October 2019 13:30
#5
boot2k3:
release_delay = 121
Thanks, I’ve already applied this release_delay value.
It seem works but sometimes some presses still skipped:
Oct 11 03:26:30.686310 CoreELEC kernel: remote: press ircode = 0x00,
Oct 11 03:26:30.686827 CoreELEC kernel: remote:
Oct 11 03:26:30.687127 CoreELEC kernel: scancode = 0x006c,maptable = 0,code:0xff007984
Oct 11 03:26:30.935802 CoreELEC kernel: remote: release ircode = 0x00,
Oct 11 03:26:30.936069 CoreELEC kernel: remote: scancode = 0x006c, maptable = 0,code:0x00000000
Oct 11 03:26:31.055855 CoreELEC kernel: remote: Wrong custom code is 0xfc01f984
Oct 11 03:26:40.535899 CoreELEC kernel: remote: press ircode = 0x00,
Oct 11 03:26:40.536779 CoreELEC kernel: remote:
Oct 11 03:26:40.537258 CoreELEC kernel: scancode = 0x006c,maptable = 0,code:0xff007984
bam
11 October 2019 14:03
#6
I have following in my android’s mesongxl.dtsi
and I don’t recall any problems with it:
remote:rc@c8100580 {
compatible = "amlogic, aml_remote";
dev_name = "meson-remote";
reg = <0x0 0xc8100580 0x00 0x44>, /*Multi-format IR controller*/
<0x0 0xc8100480 0x00 0x20>; /*Legacy IR controller*/
status = "okay";
protocol = <REMOTE_TYPE_NEC>;
interrupts = <0 196 1>;
pinctrl-names = "default";
pinctrl-0 = <&remote_pins>;
map = <&custom_maps>;
max_frame_time = <200>; /*set software decoder max frame time*/
I wonder what the reg
values mean, and shouldn’t I reproduce something from that section in my remote.conf
somehow?
@anon88919003 @Portisch
your factory_code is wrong in remote.conf
bam
12 October 2019 13:10
#8
As I said, it happens occasionally. Most of the time it works ok
