i’m not sure, if this is the right forum category. I was playing with an Odroid N2+ and wanted to check the documentation adding an LED and power button (see Power Off and Wake Up using GPIO Key Button.
But my main problem is regarding fdtset/fdtput using the N2 dtb (g12b_s922x_odroid_n2.dtb). All commands (including fdtdump) fails with
FATAL ERROR: g12b_s922x_odroid_n2.dtb: header is not valid
After testing all other dtb i’ve found out, that all of these dtbs throws the same error:
g12a_s905x2_beelink_gt1_mini.dtb
g12a_s905x2_beelink_gt_mini_a.dtb
g12b_bananapi_m2s.dtb
g12b_s922x_beelink_gs_king_x.dtb
g12b_s922x_beelink_gt_king.dtb
g12b_s922x_ugoos_am6b.dtb
g12b_s922x_ugoos_am6.dtb
gxl_p212_lepotato.dtb
sm1_s905x3_beelink_gt1mini2.dtb
Nevertheless, at least the N2 boots fine and i’ve not found a problem.
The image i’ve tested is the official one from GitHub (19.5-Matrix)
Exists there a solution/workaround or an explantion for this problem?
