I’ll post my log later when I can get to a computer that is on and the issue occurs. In any case, I wanted to see if anyone else is experiencing a static feedback noise upon Kodi starting using the new CE version update that came out. If I restart the box all is good and the sounds are fine. If I don’t restart it every sound is just loud static.
Try changing passthrough setting and device setting. If that doesn’t work, hang tight. An update is imminent and there are a sound related commit or two in there.
Thanks, I will try it out and report back.
