Hi there!
Again I did. I accepted the advice. I install the CE vorke Z6 + ra. I did not set the network to direct anything. Everything worked! Power off. Approx. half an hour, you CAN NOT CONNECT to the REMOTE SERVER!!!
UPNP folder is empty!! And it’s just under CE!
