Please add the linux driver for the XBOX One wireless dongle.
There’s a repo for the linux driver here: https://github.com/medusalix/xow
According to the repo maintainer it works only on amlogic-ng platform.
Thank you very much.
It’s already added in EmuELEC.
Oh really? I have to try that, too!
Sorry if I have been unclear but it’s the EmuELEC addon for CoreELEC 9.2.2 on Odroid N2 I‘m after and in CE the dongle doesn‘t work:
[ 1345.677347@2] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd
[ 1345.802297@2] usb 1-1.2: New USB device found, idVendor=045e, idProduct=02fe
[ 1345.802299@2] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1345.802301@2] usb 1-1.2: Product: XBOX ACC
[ 1345.802303@2] usb 1-1.2: Manufacturer: Microsoft Inc.
[ 1345.802305@2] usb 1-1.2: SerialNumber: 293059
[ 1345.803341@2] usb 1-1.2: Unsupported device
I would really appreciate to have said driver included in CEto be able to fully use the EmuELEC addon.
Thank you @anon88919003!
Have you tried installing EmuELEC rather than using the EmuELEC addon?
Yes, It doesn‘t work there either. It doesn’t look like the driver is included in the current 3.5 version. So I have ressurrected the FR on the EmuELEC github page.
