@nioncode, would be great if you could have a look at below.
I’ve cryptesetup with all libs as reported by strace put in what I export as LD_LIBRARY_PATH=/flash/crypt/lib
The /flash/crypt/sbin/cryptsetup exists too though everytime I try to run it error says "not found". This is rather weird message and smells like something is missing on busybox side to start.
Insmod is done, there is no such string in cryptsetup.
The cryptsetup I’ve is one retrieved using opkg install cryptsetup. It is 2.1.0-2.
I’m getting a bit clueless for the moment.
Content of /flash/crypt/ is:
./dm-mod.ko
./sbin
./sbin/cryptsetup
./dm-crypt.ko
./lib
./lib/libpopt.so.0
./lib/libgcrypt.so.20
./lib/libuuid.so.1
./lib/libcryptsetup.so.12
./lib/libm.so.6
./lib/libdevmapper.so.1.02
./lib/libblkid.so.1
./lib/libcrypto.so.1.1
./lib/libgcc_s.so.1
./lib/libpthread.so.0
./lib/libc.so.6
./lib/libssl.so.1.1
./lib/libjson-c.so.4
./lib/libdl.so.2
Thanks in advance.
#UPDATE:
Managed to get statically linked strace from (as later trail&error shows - some basic libraries are missing still):
Using it I’m getting this:
execve("/flash/crypt/sbin/cryptsetup", ["/flash/crypt/sbin/cryptsetup", “–version”], [/* 19 vars */]) = -1 ENOENT (No such file or directory)
write(2, "/flash/bin/strace_static: exec: "…, 58/flash/bin/strace_static: exec: No such file or directory
) = 58
mprotect(0x7f7d109000, 4096, PROT_READ|PROT_WRITE) = 0
mprotect(0x7f7d109000, 4096, PROT_READ) = 0
munmap(0x7f7d109000, 4096) = 0
exit_group(1) = ?
+++ exited with 1 +++
UPDATE2:
with trail&error approach I’ve figured out that the list of libraries I’d need to put on the flash is much longer though even if this list it doesn’t work:
ld-2.27.so
ld-linux-aarch64.so.1 -> ld-2.27.so
libblkid.so.1 -> libblkid.so.1.1.0
libblkid.so.1.1.0
libc-2.27.so
libc.so.6 -> libc-2.27.so
libcrypto.so.1.1
libcryptsetup.so.12 -> libcryptsetup.so.12.4.0
libdl-2.27.so
libdl.so.2 -> libdl-2.27.so
libgcc_s.so.1
libjson-c.so.4 -> libjson-c.so.4.0.0
libjson-c.so.4.0.0
libm-2.27.so
libm.so.6 -> libm-2.27.so
libpopt.so.0 -> libpopt.so.0.0.0
libpopt.so.0.0.0
libpthread-2.27.so
libpthread.so.0 -> libpthread-2.27.so
librt-2.27.so
librt.so.1 -> librt-2.27.so
libssl.so.1.1
libuuid.so.1 -> libuuid.so.1.3.0
libuuid.so.1.3.0
