Hi it’s been a while since I last posted or used coreelec but today I turned on my vim3 went through the auto update process which must have been about 2 months newer than whichever version I was on before and after the update all my movie fanart is very grainy and poor quality. A long long time ago I remember I had to edit a setting to make the fanart higher resolution is this still possible? If so could somebody point me in the right direction so I can get them back to high res
Box is VIM3 pro CE on EMMC single boot
use 4K (3840x2160) GUI resolution. with GUI in FHD (1920x1080) my movie posters are grainy.
My gui is set to 4K already (3840x2160)
search for “fanartres”, which can be set in advancedsettings.xml. maybe your update changed your advancedsettings.xml
Advanced settings are set to
imageres 9999
Fanartres 9999
Is this correct?
My advanced settings are:
<advancedsettings>
<!-- enable debug logging 1=enable without OSD 0=disable -->
<loglevel>0</loglevel>
<!-- Change Covers and Fanart Resolution. Defaults are 720 and 1080 -->
<imageres>1080</imageres>
<fanartres>1440p</fanartres>
</advancedsettings>
