EDIT
I got it working by editing the config.ini.
But for 4K videos the GUI when paused and the subtitles are all black and dark. Not visible. Any idea how to change that?
I just recently came across CoreELEC and I installed it on my android box.
I tried the latest 9.2.4.2 with the g12a_s90X2_1g.dtb and all I got was a black screen but I still got input signal of 1080p but no video output.
So I decided to try out earlier versions and the only version that worked was 9.2.1 and lower versions. After 9.2.1 all the other three versions give me black screen.
Now the problem with this version is the UI is green. Video is good but everything else is just green.
I read on the forum that I have to uncomment a lint in the config.ini but I use a mac so I need help doing that.
Or is there any other way to solve this?
(I can’t update because the other versions will result in a black screen)
