I have the above name device and it can’t find the tee loader on startup because of a missing super partition. It runs Android 11 and the vendor seems to have dropped support so I am not expecting this will change.
Working with Claude the issue appears to be that the logic doesn’t read the A/B device correctly and my device boots from system_b. Claude was able to fix this and I now can play video fine and I’d like to PR the change. This equires a patch to CoreELEC/projects/Amlogic-ce/packages/parse-android-dynparts at coreelec-22 · CoreELEC/CoreELEC · GitHub to support loading from a different slot instead of just ReadMetadata(device, 0)
My question it it better to PR just CoreELEC/projects/Amlogic-ce/packages/linux-drivers/amlogic/opentee_linuxdriver/scripts at coreelec-22 · CoreELEC/CoreELEC · GitHub with patch for the parse-android-dynparts package or to update both packages?
Martin
